Can't remove clock
    Can't remove clock
    I've been tryin to remove the clock from my accord and it won't budge.....I know you're suppose to remove it from the left side but the left side won't budge. The right side comes out enough to put my fingers behind it but the clock seems stuck. Is the clock any different on a accord se?
    This is wierd.....I just replaced my clock today. To get it out....there are these prongs holding it in from behind....mine wouldnt budge until i broke the prongs by pulling too hard. So if you don't have a replacement....just stick somehting in the gap and depress the prong and it will slide out....other wise....just yank on it hard
    Finally...the drop! (I know it aint much, but I love it! )
    Ebay Whore Crew #7
      yeah man just pull that thing hard, it will come out, you can put the clamp thing back on dont worry about breaking it.
        took me a whie also, i found a way to get the flat head back there and depress that one tab.
          monster flathead is the trick.
          Honda-Tech Username: Lostcb7
          The cb7tuner.com OG.
            Originally posted by cpmike
            ---to remove the clock, pry it out from the center of the left side with a flat screwdriver. once the left side is all the way out, pull the clock out and unplug it. DO NOT PRY THE CLOCK OUT FROM THE RIGHT SIDE.
            http://www.cb7tuner.com/vbb/showthre...&threadid=8089
