ok, so about a month ago I did a swap and took it for a spin...well when I was test driving it the arm that sticks out the vss to mount on the tranny broke...so I went to the jy to get another one but I just put my top electronic part on the vss on the bottom part of the jy vss. After installing it my speedo wasn't working...so I asumed maybe my little electronic sensor coincidentally broke as well...so a freind took his off and we installed his entire vss on and still nothing...
well we went and did some research (<link) to find out what the wires should read out and found that black (of course) goes to ground, the middle (yellow/blue) should have 5v and the yellow/white is signal...but the yellow/white just has a constant voltage reading when we spin the wheels...I'm thinking thats my problem...that it shouldn't read a constant voltage, it should go from 0v to 5v to 0v to 5v...and so on...when we spin the wheel...
we even wired the wires straight to the ecu to make sure there wasnt a break somewhere in the harness...but nothing is working...
everything was working untill the mount on the vss broke...I am so clueless...
I was wondering if any body has any clue how to check (if I'm correct) why the signal wire just has a constant reading....
or if anybody had the same problem...
