how much is it to replace the transmission fluid. im prolly going to take to a good friend of my mothers, and im wondering how much it is
How much is to
For an auto transmission all you need is a jack, a drain pan, a rachet, ATF, and a fluid cone.Originally posted by killin View Posthow much is it to replace the transmission fluid. im prolly going to take to a good friend of my mothers, and im wondering how much it is
For a manual you need about the same, and you can put the fluid in through the speed sensor or another location, i just can't think of it. Or if you want to do it the hardway you can get a pump and push the oil back in through the fill hole.
I would say somewhere between 20-60 bucks?
Careful when you do this someone did it and his tranny never worked again, because the "bearings" are used to being lubricated or something on the lines of that.Originally posted by killin View Posthow much is it to replace the transmission fluid. im prolly going to take to a good friend of my mothers, and im wondering how much it is
Yeah I've heard stories that when you flush the tranny out some of the metal pieces that were necessary and stayed intact because of the fluid, end up getting pushed out by the new fluid, creating a world of new problems.Originally posted by Reignstarz View PostCareful when you do this someone did it and his tranny never worked again, because the "bearings" are used to being lubricated or something on the lines of that.
ok how much would it be to take to a shop?
also im trying to narrow down what my transmission is doing or i need to place it. here is a message i put up at yahoo answers and maybe you guys can help me more then they can
i have a 1992 honda accord wagon. im not sure what is causing this issue but when ever im in gear for 10-15 miles all of a sudden it takes its self of out gear and never goes back then i shut it down and restart goes for a few more then does it again. do i need to replace the transmission, TCU or the torque converter
thank you
Edit 1 :i did check the fluid and it was black
Edit 2 : would changing the fiuld and filter cause that issue?
Joe
