Electrical gremlins
    Electrical gremlins
    Ok my friend called me the other day with some electrical problems. He says that when his Accord (CD5 coupe...I know this is CB7tuner buuuut....) when warmed up will start acting a little funny. His headlights dim and the cluster goes nuts! He also has a clicking noise under the dash in the glove compartment area when this happens. But when its cold it acts fine and only does this when warmed up. He has replaced the entire charging system and its draining his battery overnight whatever is causing this. I am going to send him to the local advance auto to make sure everything is charging properly. Please let me know if this may be a common problem and can be fixed easily. Thanks!
