battery draining
    battery draining
    Im tryin to figure out wtf is draining my battery. Battery is good, next morning, cant turn over.
    Is that green halo light around the ignition normal to be on 24/7 even the car is off?
    Where else should I look at? I have no alarm, no audio system.
    I do believe the ignition light only lights up when the driver's door has been opened... at least thats what it's like for my moms 626 (I don't pay attention to my car anymore).
    Might want to check to see if your door is being left ajar.
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      In my experience that light should only come on when you open the driver door. Maybe one of your door sensors went bad?
        I ran into a problem where my alt wasnt charging enough. It was enough to let it run but once I cut it off it would be hard to start and sometimes not start at all.
        Not being a dick but how do you know your battery is good?
          it could be the alternator...
          i ran into the same problem a couple weeks ago. thought it was the battery but the guy who checked it said my alternator was shot. replaced it and had no probs after that. hope this helps out
            did you clean both negitive and positive terminals. make sure you have a tight connection in your wires as well.
            hope it helps
              ok... first of all there is one test that tells you what is draining the battery ,... that is called
              BATTERY DRAIN TEST
              Tools needed
              Digital Mulitimeter with amperage metering capabilities
              Jumper wire
              Fuse puller
              Here are the procedures for that ...
              Drive car around for about 20 mins.
              Park car and let sit for about 45 min.
              Ok now hook up a jumper wire between the post and battery cable of the positive side of the battery
              Now hook up the multimeter between the post and battery cable
              Take battery cable off post with multimeter and jumper wire hooked up
              Now remove jumper wire
              Take multimeter reading
              Should read less than 0.050 amps
              If more than that .... start to pull fuses until the readings drop down to those specs...
              Once that fuse is found ... look what it controls and go from there
              if any more questions ... just google
              Battery Drain Test
              ... i tried to remember how this is done by memory ...
              Originally posted by Devergote
              A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                Good how to. Maybe post that in the DIY?
                  x2
                  you can also take your alternator to your local auto parts store and have it tested.
                  Originally posted by visualpoet
                  some owners think it's the best thing since titties
