Okay as some of you guys may know I just got my car running again after my blown headgasket situation. I'm having some issues at the moment and I'am stumped on what could be my problems.
1. for some reason I can't rev past 3.5k rpms my car it feels strong but once I get to that rpm range it's doesn't go any higher.
2.I have very loud ticking noise from multiple valves it sounds like I have stage 2 cam in my car. I just did a valve adjustment with in the specs of .009-.011 on the int side and .011-.013 on the ext side. The car does start up easy without hesitation and idle's nice and starts all the time,it doesn't smoke or anything, the acceleration is there until 3.5k rpms as mentioned above. the only thing that is odd is that my spark plug tips have a lot of carbon build up which they're new just put them in today. should I re-do my valve lash to a tighter spec to see if the ticking stops?
Also what are the symtoms of bent valves. I just want to know to be safe.
