my brake lamp light came on, and my brake lights are working so what does this mean?
brake lamp light
happened to my old car, i just figured it was the brake-out detector circuit, which i believe are the brown and black boxes mounted inside of the tail lights.
i just left it on, i knew my brake lights worked fine.
they may be on when you have your lights on but since they are dual filament bulbs it is possibly that when you put your brakes on with the lights on that one might not light up as bright as the others. back up to a building that you can see your reflection in easily in the windows and then turn your lights on and also press the brake pedal and see if they all light up with even brightness."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
