trouble code
    trouble code
    i have a 93 h22 and i got a dtc that is 36 but i cant find what it is..does anyone know?
    Distributor, or at least that was the case with my buddy's CD5.
      Traction Control
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        Oh, I read "tdc" as in "top dead center". lol
          its not traction control and i know its not my distributor its ok
            deleting code
            how can i get rid of this code?
              Is it fixed ? You can reset the ecu by disconnecting the neg. battery cable or simply pulling the ECU fuse in the under-hood fuse box ( 10amp) for 15 seconds.
              -1992 CB7 EX w/H22 [sold 10/09]
              -2005 Legacy GT limited [current]
                no were is the knock sensor located at cuz it says its under the second fuel injector but i dont see anything...anyone have any pics?
                  Code 36 doesnt even exist.
                  www.PreludePower.com
                  BB SQUAD MEMBER #28 V.2
                    yes it does its only found on jdm ecus... i have a p13 ecu
                      The knock sensor is on the back of the block, above the oil filter. If you look in this picture, you'll see the hole for the oil filter, look just above that, the one in this pic is broken, but you get the idea.
                        Yea you just need to go get all the bolt ons you want and go get tuned. I have heard that those P13s are crap.
                          is that for a h22??
                            Yes, that's on my h22
                              alright thanx....is it a single pin connector or a double pin connector
