odd temp gauge problem
    if i start the car and let it heat up the temp gauge will read as normal. when i start driving it will cool down a ton, like to the point its all the way on cold. im thinking thermostat stuck open? any suggestions?
    also, im sure you guys are familiar with that cluster of fuel lines that bolt to the frame right after the tank on the drivers side of the car right under the rear door. well, its leaking.
    on my last cb7 the part was dealer only, and over $100. i just replaced it with a reg rubber fuel line, is this ok? it seemed to work just fine on my old car. thanks!
    94 Honda Accord EX - cozy daily
    95 Civic DX w/ lamesauce b18
    92 Honda Accord Discount Xtreme - 400k miles strong
    04 Honda Helement EX AWD - GF's ride
    could also be a bad coolant temperature switch
