F22B Distributor Help
    My dumba$$, unplugged the wires from the distributor without thinking of remembering which one went where. So if you have an f22b, can you look and see where the 1st spark plug wire(from the 1st cylinder) goes where on the distributor cap. I appreciate the help.
    Shift_BOOST
    BOOM!
    and where the rest of the plugs go
    Shift_BOOST
    BOOM!
      Firing Order= 1-3-4-2
      Dizzy= Bottom Left terminal is #1, then go clockwise following the firing order, like so:
      -3-4-
      -1-2-
      Looking at the valve cover standing on the exhaust side(header); 4-3-2-1 #1 cylinder is the closest to the belts.
      Jay
      Hittin Switches - Draggin XhaustAlways Under Construction
        Damn your on it like white on rice! akkord
          Someone has to help up since your slackin phatty
          Jay
            thanks for the help. you just saved me a lot of frustration and possibly me engine.
            Shift_BOOST
            BOOM!
