Dizzy????
    Dizzy????
    so yeah guys, quick Q's? my car is bogging at 4,000 rpms! Every time i did a motor swap i always have electrical problems... this time it was burning out my coil?? so u think dizzy since i never changed it out for the past 3 years or maybe a fuel pump??? cause it has trouble starting! Need help fast, need to get this shit running right!! THANXZ
    bump
      ok so you did a motor swap .
      any specs on that motor ?
      -->751 whp @ 27psi <--...Midnight Tuning <----
        the specs are H23 head on F22a6 block
          what distributor are you using H23 or F22?
            what ecu?
              iam running a chipped po6 ecu with a f22B base map, and iam useing H23 dizzy....help
                bump
                  recheck your cam timing. i had the exact same setup but the cam timing was a bitch, even the same ecu...p06 with f22b basemap.
                  after everything the car ran like a raped ape.
                    But i did i check the timeing..... that was the fist thing i checkded... I also was thinking maybe TPS??? so tomorrow i was going to the junk-yard.... any more ideas of what it could be????? I did forget to mention about the check engine light.... it only comes on when its cold or just when i start my car without warming it... I'll be driving and it star ts boging at really low RPM's and then it will work until i hit 4,000 rpm's and then the boging issues happen again..... BUMP
                      well pull code and see what it is.
                      sounds like maybe an igniter.
