Water Leak
    Water Leak
    I'm pretty sure that I have a coolant leak from my water pipe. It looks like its coming from the water pump side of the pipe. Does anyone had any experience with this? Anyone ever fixed this before?
    Thanks in advance for the help
    JB weld and some duct tape is your friend! Keep an eye on that beast, no coolant=pow.
      usually man that means a seal or your actual water pump is on its way down...is the pump making any abnormal sounds?
        well. there is a hard hoze that goes fromthe bottom of the thermostat hosing to the water pomp. now this pipe i think its in two pieces. and there is a seal on the thermostat housing a seal in the middle and a seal in the water pomp. just check and see where the water comes from. don't just put ur head under the car and see which side the leak is.
          yeha exactly what Alb said...i wonder how hard it would be to change that tube anyway, its in a weird place. i bet it cost a a lot too.
            Has anyone ever repleced these O-rings? do I need anything to do the job other that the ring itself?
