Car Won't Start! Help Please
    Alright everyone, I picked up a '93 SE coupe. Everything was working fine, until today. I was going to disconnect the ABS unit (Yes, I know, not safe), and after I did, the car wouldn't start. It will start for like a second, then go dead, and the starter will just try to start the car and do nothing.
    Here's the thing. The car has an OEM factory alarm system. I think I may have tripped the immobilizer when I unplugged the ABS unit. This is all just me guessing though.
    If anyone else has an idea on the problem, let me know.
    And please, for the love of God, type like a human being!
    No ideas? The car will catch for like a half second, then after that the starter just tries.
    Anyone?
      It can be your Main relay. ALmost everyone goes through this symptom since our cars are old. All you need to do is take out the main relay and resolder the joints. Search " Main Relay" and a Do it Yourself should show up. Hope this helps
      If all else fails, checkup on the alarm, and or your fuel pump.
      "PREPARE for the WORSE, Hope for the BEST" B.T.N.H.
        why not plug everything back in and see what happends.
        Retro!
        Hater
          I agree with that, but also check all the battery connections, ecu connection, plug wires, make sure your fuses are in all the way, etc. I'm also an advocate of resoldering main relays, hell for the 15 minutes of work/contortionism, and probably one cent worth of solder it works like brand new.
          Cars:
          91 Accord LX Sedan (sold)
          98 Accord LX Sedan
          95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
            That's a good idea. I'm going to have to check the main relay out. I thought it usually happened in very hot weather conditions though. Oh well, it can't hurt to check.
            I already tried that. Still the same.
