i'm getting a rattling noise during cold start-ups and it sounds like something might be bouncing around near or below the T-belt cover. anyone ever had an issue like this only when it's cold and warming up?
rattle near/below the T-belt cover
Check your crank pulley, there is a rubber dampener ring that holds its 2 pcs together, I have seen them crack and separate. You'll get a dead battery after that since alternator will stop rotating and potential block damage, if it gouges it while rotating. Remember our cars have been around a LONG time.
Also, how long have you been running the current timing belt tensioner pulley? They can last 200K miles, then I replace. Basically, replace every other timing belt job. Same question/replacement interval for your balance shaft belt tensioner pulley, you can remove this balance shaft belt and still operate motor, if noise goes away then you know what component is damaged.
I would also inspect timing belt tension. Maybe your adjuster nut backed off, was not torqued properly. Maybe you have a worn timing belt, that should already have been replaced?Last edited by HondaFan81; 10-20-2009, 01:30 PM.
Originally posted by HondaFan81 View PostCheck your crank pulley, there is a rubber dampener ring that holds its 2 pcs together, I have seen them crack and separate. You'll get a dead battery after that since alternator will stop rotating and potential block damage, if it gouges it while rotating. Remember our cars have been around a LONG time.
Originally posted by Accrdwgnguy View PostCheck your front balance shaft pulley. I had a rattling sound for the longest time but sounded like it was coming from the head until the pulley fell off because of improper torque. Shredded my Honda timing belts too, but thats my fault.
well, today it happened. i got to my parking spot at the train station and when i got out to leave, i see coolant dripping under the car from the t-belt cover. looks like i need a water pump.
the car is now sitting in the driveway, dripping away coolant. gotta order the pump, belts, tensioners, etc...
Glad it wasnt the crank walk!!!
I thought they would usually make a squealing noise but I guess its a rattle. Have fun with that timing belt and make sure everything is good and tight especially the crank pulley. Also see if you can located the crank pulley tool, it will make your life NOT a living hell so try and get that tool.
