Egr
    Egr
    well i cleaned my egr yesterday cuz i had a cel #12 so i cleaned it and reset the ecu but it came back on? any way of testing the EGR? can it be vaccum?>
    CB7_HULK SMASH!!!
    Could be that the six egr ports are clogged up. In that case, you need to pull the plugs and spray carb cleaner to clean it up.
    also make sure the egr VALVE opens and closes.
    -1992 CB7 EX w/H22 [sold 10/09]
    -2005 Legacy GT limited [current]
      i got a f22b2 do i do the same thing like the f22a4 to clean the ports?? mine looks like it gots a cover on top of the ports ?
      how do i check to see if the egr opens and closes?
      CB7_HULK SMASH!!!
        you can check it manually by putting your fingers under the egr disc and pull up.
        id suggest checking it with a vacuum pump. does the car idle rough but fine at 1500+rpms?
        I <3 G60.
          it idles ok i just cleaned the other sensort the iacv and the tiacv
          i lifted with my fingers and it does goes up
          CB7_HULK SMASH!!!
