help with a few more problem's
    ok i drove the car to work today and noticed that everytime the clutch is pushed in it revs till 3k rpm. is there anything that might be causing this? i think it might be some of the vacuum hoses that are put wrong or maybe need to bleed the cooling system?? any help will be appreciated
    does it hold at 3k or does it rev up then come back down?
    4 door pimpin'
      Does the clutch feel weird? try rebleeding the slave cylinder and see if that helps.
      member's ride thread
      91 Accord SE 176k
        no it just stays at 3k rpm. and yea i blead the clutch and still no luck. wat else could it b? and my tach comes off and on at random times after i did the swap.
