For the pass 8 months Ive had code 10 for my tcu making my S light blink. Also everysince this code has been flashing, I am having a hard time starting after letting the cb sit for so long, usually like 4 hours or so. I have changed so far:
Fuel Pump
Fuel Regulator
Water Temperture Sensor (front water neck)
FITV
Sparkplugs
Sparkplug Wires
From my own personal expieriance I did a wire test on the connector, going to the Water Temperture Sensor, and one is getting power, the other is grounded. I also replaced the connector. Some symptoms that make me think sumthing is wrong is that, after turning the key 15 to 16 times to get it running, its fine, But as soon as I get it crunk, it idles like its warmed up wen the cold/hot needle is still showing cold. My car idles at 600 during the warm up period basically. I replaced the water temp. sensor, reset the tcu and ecu and still no luck.
Fuel Pump
Fuel Regulator
FITV
Sparkplugs
Sparkplug Wires
but could my hard stop problem have anything to do with me grounding my amp on the same screw as my fuel pump
