I would like to replace my rear lights and side lights. I download the manual but I did not see anything on how to do this. I might have download the wrong one, does anyone know where I might find the complete manual?
Replacing lights
if you cant find the manual online, go to your local library and look for the haynes manual there..
edit: or are you just talking about the bulbs? if just the bulbs, it's very simple.. pop the trunk... open the little plastic thing where the lights would be, twist the harnesses and pull, then pull out the light and put the new one in.. for the side lights, you need to pull out the entire marker thing... pop the hood, there's one screw.. then pull on the corner light towards the front of the car, it'll pop out... twist the harness and then pull out... pull out the bulb and put in a new one..Last edited by dwf137; 12-16-2004, 03:48 PM.
