so my balancer belt snapped wen i wiz driving. we took off the timing cover and the countershafts are seized!! wut does this mean? also the timing belt almost slipped off and it skipped a few teeth. i dont want the balancer belt on anyways but still need to know wut this means.
please help i have a headache
both are seized? weird. especially if they both seized at the same time.
how many miles on the engine?
i would think that something mustve broke internally and rendered the shafts immobile. maybe jammed your crank or cams as well causing the tooth skip.
i would take everything apart (maybe even pull the motor) and see if you can find the source of the problem. if something let go inside and cooked your motor youre gonna have to pull it anyway...
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
the bottom pulley? as in the CRANK pulley?Originally posted by cleanjdm View Postlooks like the bottom and the one to the right seized as well as the exhast camshaft.
something got fucked up good if 3 out of 5 belt driven shafts seized.
expect some serious engine work in your future.
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
your motor is certainly fucked for the time being.Originally posted by cleanjdm View Postsorry in a hurry but its the crankshaft and the one to the right of it.
whether its rebuildable or not, you wont be able to tell till you pull it and take it apart.
bummer.
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
yea no biggy though i'll jes get another jdm block and/or build this one up. high comp setup.Originally posted by H22artman View Postyour motor is certainly fucked for the time being.
bummer.
1991 Lx coupe........traded now I have nothing lol
