Attempt at lowering engine bay temps
    I have a reason to believe that the heat in the engine bay is killing the electrical modules. So far in 5 years, ive gone through 3 ICM's, one coil and one fuel injector resistor box.
    car runs good, never overheats and fan comes on every once in a while so i know it works.
    Suggestions:
    -lower thermo fan switch
    -isolating the coil away from the distributor ie: going to external coil
    -running a vent tube to cool the distributor
    -hood stand off (i know a lot of people dont like this but i guess it is better than being on the side of the highway with a no start)
    -custom phenolic gasket for the distributor
    vents in the bumper coupled with vents in the hood? could custom do them
    *sigh...or do the hood mod...would be faster/easier and effective
    custom "soda can" heat shields maybe?
    move electrical boxes?
    I know...re-connect a/c...run all a/c vents into engine bay to blow on boxes
    ____
      Suggestions:
      Just convert it to an external aftermarket coil blaster, easier and everything. They are only 30 bucks. All your worries go away.
      Retro!
      Hater
        yea im about to do that, just need a couple more dollars. (trying to get tires at the same time doesnt help)
          92-93 comes with external coil right, i know my lx has one. But if we went to a MSD blaster coil, we would still need the ICM right?
            lol, any car needs an ICM otherwise it wouldnt know when to fire.
              thats what i figured, just wondering how changing the coil, will help anything in this scenario, other than having a better coil, that might hold up to the heat better than oem
                Have you tried wrapping up the exhaust manifold/header? Thats the number one cause of heat in the engine bay.
                  putting on a header wrap does help with under hood temps. i pop the hood after a run and theres a CRAP load less heat coming from under there. i think i can actually feel the car accelerate smoother after i wrapped it.
                    kinda, the crank sensor sends a signal to the ICM to turn off and then fire its secondarys.
                    basically if you do the external style or a add on coil, it will be the same thing. It will recieve a signal and when the signal shuts off it will shoot a spark to the spark plugs.
                    Getting it out from under there and mounting a new one will help him, even though I never had the issue myself unless he is using cheaper non oem ICMs.
                    Retro!
                    Hater
                      header wrap or hood stand off or both.
                        One important thing that people often forget is the thermal paste that goes between the distributor housing and the ICM. It's exactly like a CPU and a heatsink, it needs a good transfer medium to fill in the gaps. This helps cool the ICM. Most people I know that have replaced ICMs neglect to use the paste included with it. I'm 99% sure that this leads to an earlier failure of the unit.
                          The hood standoff is fine with me, it actually serves a purpose.
                          Maybe you could wrap your icm with something?? Im not sure, I wonder why its so hot under your hood versus like mine?
                            get a 10 or 12" slim fan and hook it up to a switch. it will make a big difference.
                              Yes - wrapping the header drastically lowered engine bay temps for me.
