After rain CB is acting up..
    wassup people just wanted to know if anyone could help me with this..im going to record a video shortly..but for some reason out here in FL when it rains for like 2 days straight my car tends to develop a nice big puddle in the trunk under the spare..and i've read threads and come to find out its a known problem with our cars after awhile..but for some reason the water literally reaches my back passenger seat and back driver seat on the floor..like a puddle there also..this somehow attributes to my car acting up as i was driving home yesterday and it was working fine but then when i turned a corner my car just cut off for no reason..all the electronics stayed on..so i kept trying to get it to turn on for 40 seconds on the road..and it finally worked..was able to drive it home...so i came home ate..came back outside to check it..when i turned the key now all of a sudden my check engine light is now on..and now my car idles a little higher than it suppose to..normally it would idle a lil below 1000 rpms now its idling around 1200 rpms AFTER it cools down also..im uploading a video now so when it goes through i'll post it..
    Lou's Build Thread!
    http://www.cb7tuner.com/vbb/showthread.php?t=181377
    "G-Squares Are For Assholes"~PR_CB7
    Check for puddle in your ECU location (front passenger footwell).
      Yes, just like Hondafan81 stated, check for any water around you ECU, it can cause damage....
      ______________________________
      "I ran open header once, it was sooooo loud little kids were running for cover as I was cruising at 2000rpms. That was enough to know I shouldn't floor it."
        yea definately soaked! i toook a towel to it and dried it out a bit..crazxy thing is i came home from driving all day with check engine...came home ate something...got in my car and check engine light is gone..now its running fine like normal.
        Lou's Build Thread!
          Yep. It's amazing what water can do. It will destroy your electrics.
          HondAccordMan-1991 Honda Accord LX Sedan
          Click for MRT thread
            Take the spare out o your trunk and pull the 2 grommits out of the trunk.. say bye bye to your water problems lol
            -Will
              its probably your seals, could be window but also could be a door seal. In the trunk, the tail lights have gaskets inside of them, those are probably worn or gone completely if you haven't replaced them recently
              member's ride thread
              91 Accord SE 176k
                your cel is supposed to extinguish.
                I <3 G60.
                  Yea and you might want to re-gasket all the car....from doors to trunk....
                    yea im sure its probably coming from the lights... normally when i open the trunk the whole light is almost filled with water..you can see it flush out into the carpet..i also removed the 2 rubber pieces bullhorn mentioned..thanks ppl for the help
                    Lou's Build Thread!
                      You're outta gas bro.
                      Member's Ride Thread
                      Originally posted by mercyboy
                      I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
