pretty much what the titles states pretty much when i turn the car on it'll be fine but once i start to drive or rev the engine a bit the light turns on and it starts beeping..its REALLY annoying...and it was off for awhile but i had punched the gas one time and it turned on and it's sorta been on ever since..anyone know what could be causing this problem?
Seatbelt light turning On While Driving/Idle W/ VID
Lou's Build Thread!
http://www.cb7tuner.com/vbb/showthread.php?t=181377
"G-Squares Are For Assholes"~PR_CB7
Tags: None
I had a weird problem like that in my friends car. Ironically it was the cluster shorting.
It did weird things, it did what yours did, then the oil light will blink just like the seatbelt light.
I took it out and fiddled with it and found it to be the board itself...i fixed it with cardboard pushing on the connector lol
but that was after alot of trial and error to check the other systems first.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Yeah. Mine would flash when I floored it just after I stripped my car. Turned out I didn't have the plugs in extremely well when I reinstalled the computer and when I got on it it was breaking connection. Just pushed the plug in and snap problem solved.Originally posted by Bullhorn7 View PostCould be the actual seatbelt computer itself.. Go to the junkyard and get one.
Its located under the passenger seat.
