Any input welcome....
    As some of you may know, Ive been having a problem with my car not starting right off after sitting for so long, so after letting it sit for about a day I went out to tha car and loosen the fuel rail bleed screw, not a drip of fuel. Also, about a year ago before I had this problem, my (air/fuel ratio gauge which reads green when running rich orange when perfect mixture and red when lean) it ust to stay green untill my car was warmed up then it would slowly receed to orange then jump back and forth, now after about 20 key turns to get tha car started it bounces back time its able to stay crunk like its already warmed up any input will be useful
    so you decided to not take any of our input from the older threads and just start a new one in hopes to finding an easier route or solution?
      of course not, I did everything you guys said to do, I replaced tha sensor with a working one, I replaced the Fitv and I checked for spark and fuel, I loosen my fuel rail bolt after lettin gmy car sit about 4 hours and not a drip of gas
        So when you try to start the car can you hear the pump priming? It's either the pump is bad or your main fuel relay under the dash. Another question is do you have gas in the tank?
        Edit: have you checked/replaced the fuel filter found on the firewall?
          you need a fuel pressure gauge and you'll need to prime the system, wait till it gets to correct fuel pressure and take the key out. it should hold pressure within 5 psi after 10 minutes.
            New fuel filter, half a tank of gas, main relay is fine. I think my fuel pressure is bleeding off sumwhere after it sits becase i let it sit for a day went out to my car and loosenend the fuel rail bleed bolt and it did not squirt out at the least ,and yes my fuel pump definitialy is priming.
              have you checked the fuel pressure regulator ?i would get a fuel pressure Gauge to check it
