camber kit problems!
    I have been reading about people using ebay front camber kits. I bought a 35 buck camber kit for my cb7 and put it on and drove about 10 yards, then it just falls back to where it was before... the camber kit would not stay where i adjusted it too. I just ordered another kit, so is there anything yall can tell me like pointers on what i might of done wrong or what? My tires keep wearing down on the inner but my alignment is good. I really need to know what i did wrong with the camber kit.
    93 accord coupe lxr
    10 fusion se slammed
    I'd go out on a limb and say it's the cheap camber kit...
    Oh and you might want to edit your sig down just a little bit, 500 x 300 or so.
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      cheap camber kit .. did u take it to an alignment shop ? your supposed to after putting in ball joints.
      get SPC front balljoints , those are the best cheap ones. will run you about 150$ for both. dont skimp out on suspension components!
      alone in this game . ::My Ride My Way::
        i didnt get the ball joint camber kit.. i got the other one where its 2 on each side.
        93 accord coupe lxr
          Have them professionaly installed .. preferably by the folks who are doing your alignment.
          They may not approve of the part you bought ..
          A good camber kit will cost a bit more for proper fitment ..
          I'm running an ingalls set up front .. you may want to look into a set from ingalls.
          Or as tear2 suggested, the spc's .. either or, are about the best way to go.
          Tomi
          My CB9/Wagon Thread Start to Finish:
          http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
            i have the same kit u have from ebay.and i basicly had to weld them.but my main problem was i had to weld washers were the bolt that goes through the hole thing cause the bushings didnt last a week.and if u move the arm to far forward it can and will pop the upper ball joint out of the arm.so becarefull.o and to help ur problem just lock tight it.
            my new turbo build
