Evaporative system unhooked
    So i was looking through a list i needed for inspection
    and it said the evaporative system was unhooked.
    i have completely no idea how to "rehook" this thing, i think its the black cylinder underneath the little box which all the vacuum hoses go into, and i saw a thick red tube coming out of it which is just chillin on top of my intake mani. This is a h22a btw if it makes a difference
    any ideas?
    I know for sure the red tube goes to the throttle body, for the rest look at some member rides and see if you can get a good look I'll try and post up a pic later.
      thanks dude, yeah i plugged the red tube in, but the rest its way to low to see in some member rides its like behind the block a lil bit
        nobody else?
        i looked in the shop manual and it called it a evaporative emission control system if that helps.
        i really need to get this fixed
          there is a vac line that goes to the top of it and the big red one that goes to it as well. If you pop off the top of the black box there are three vac lines. one goes to egr, one to map sensor and one to the evap.
          member ride thread
          DIVULGE MOTORSPORTS
            take pics of what it looks like now
            2013 Ice Cream Cruise!
            VIDEO: 2012 Ice Cream Cruise
            VIDEO: 2012 Ice Cream Cruise part 2
            The single largest cruise in the Midwest!
            August 3 ~ Omaha, NE
            By 1320 Video
            Member's Ride Thread
              follow that diagram under your hood it will show you.
              Retro!
              Hater
                The black box above fuel filter is emissions/vacuum box. From this box, one long vacuum line goes to EGR valve, one small goes into top of charcoal canister (large black cylinder under fuel filter). The MAP vacuum line (# 21) goes into TB small port, the rest of vacuum lines go into the ports on intake manifold plenum near TB. The red braided line from charcoal canister goes into the large 45 deg bend port at the TB.
                If you do not understand this, get a service manual or reference the vacuum diagram sticker under the hood, as someone said.
                  yeah i think i got it, ill take pics of it later
                    Any pics yet?
                      if you do an EGR block off plate, can ou just cap off the vac lines and get rid of the black box?
                      . . .93 Ex F2.0A Si. . .
                      WiredMotorSports
                        You still would probably need the funtion of the MAP sensor in there.
                        Retro!
                        Hater
                          You can get rid of everything EXCEPT for the map sensor. You'll have to keep that. You'll need the block off plate to get rid of the egr or else you'll throw a cel and your car will be running rich.
