Batt. Light On?
    Batt. Light On?
    Ok guys i had made a thread a few weeks back about my seatbelt light issue with it beeping...well i checked if anything was loose but everything was in place when i checked..it only seemed to beep when i had step on the gas etc or pushed the car thats why i RARELY ever did..because i knew that annoying light and noise would start beeping...well anyway thats what ended up happening..the thing was beeping non stop...i didn't know what could be wrong...now after i had left my friends house i noticed it wasn't beeping anymore..but NOW my battery light is on solid..it doesnt blink..its just on...i changed the battery today and it's still lit..i have noticed my windows go up a lil bit slower and my dashboard lights seem a lil dim before/after i changed the battery...any help on what could be causing this?
    Lou's Build Thread!
    http://www.cb7tuner.com/vbb/showthread.php?t=181377
    "G-Squares Are For Assholes"~PR_CB7
    Most likely alternator problems. Get it checked at advance or autozone.
    -Will
      the same thing happened to my car when I first got it. Go to autozone and get it checked. My alternator was not charging good voltage, so what I did is I replaced the brushes, did even had to take the alternator out, 45,000 miles latter the alternator is still working like new, pretty much I rebuilt my own alternator for $11.99 (cost of new brushes)
        ^^^^ You shall install a DIY on how to do that on this site.
          I probably will, it is really super simple to do it!
            thats bullshit cause if it was it would be in the DIY right now!!!!!! get it there!!!
            Links to my rides :
            1992 Accord EX*
            1990 Accord EX
            1991 Accord SE (4th)
            1991 Accord SE (3rd)
            1991 Accord SE (2ND)
            1991 Accord SE
              I'm going to say bad voltage regulator.
              life is good.
