ROH conversion on a 91EX
    Good day everyone! Since I'm going to be rebuilding my front end (springs, struts, bushings, tie rods) I'd figure I should go ahead and upgrade my brakes or at a min. swap to the ROH. After some research, it seems I need the following:
    2 2.3CL front hubs
    2 91 Accord wheels bearings
    Which rotors do I need for this process?
    Which pads do I need?
    Do I need different caliper mounting brackets?
    If I keep the smaller 10" rotors, can I just purchase some reman. calipers to freshen things up?
    Now my question is this, I've seen some people upgrade to an 11.1" rotor and bigger calipers. What parts would I need for this AND what about my master cyclinder on the 91? Will it be able to handle bigger rotors?
    Just need a basic breakdown of these things and rough estimate on the price to help me decide which way to go.
    Thanks,
    Cris P.
    if you want to upgrade to 11.1 rotors, you have to get the prelude brake set up with calipers, 23T bracket, prelude rotors and pads ofcourse.
      So what about the master cyclinder then? And will my stock 15" wheels fit the larger rotors and calipers?
