I was having some problems with an Axle, but figured that out. Problem im looking at now is im leaking trans fluid.
Its leaking were oil would be leaking if the rear main seal were no good. So im guessing its a seal around the mainshaft. Any ideas?
And what seals would it be? Im leaking a lot of trans fluid, the gears grind every now and then. So cheaper to get a new tranny or have mine rebuilt?
Also what does a rebuild kit usualy cost for an H22 trans. I found one for 400 here http://shop.synchrotech-transmission...C.qscstrfrnt04
Also saw the bearing kit with seal kit?
http://shop.synchrotech-transmission...It-BSK-H22.htm
Would I need both kits or what? so if anyone can help me out?
