Ok guys, so like yesterday in the morning I was heating up my car to go work, and wen I came back I had a check engine light on, but wasn't idleing nor nothing it was fine, wen I was driving back it was idleing, on 1st 2nd 3rd 4rd, on 1s gear it would idle like when you let go off the clutch too fast like if it wanted 2 turn off but it didn't , so today in the morning I was doin the paper clip trick to pull out the code but I notice wen I turned on to acc the engine light would go away wit the rest of the lights that light up ( battery light, oil light, srs light etc) and I turned the car on and the CEL would pop out put a paper clip but wouldn't do nothing it wouldn't blink, what can be the problem? Thanks in advance
CEL problems, already did the paper clip but not working
AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922Tags: None
i would have to agree, if you cant retrieve codes with a good connection at SCC then R&R the ecu.Originally posted by Shag Wagon View PostOR you probably didnt get the paper clip in there good enough. ECU could be going bad as well.
i just clipped the connectors off other cars to make my own honda SCC tool. the 90-91's and different than the 92-93's so one of those will mate.Originally posted by Shag Wagon View PostYou can also attend the junkyard and get some connectors to slide onto the blue one. I think speaker harnesses and the bulb harness inside the shifter are the connectors you can use.
thanks for the info guys, i didnt fix it this weekend i asked my mechanic and he said could be the spark plugs, the cables that are bad, destribuitor cap, o2sensor, so im going to do the tune up this weekend hopefully its just that becasue i do have like 2 yrs without changing cables nor spark plugs. thanks for the help though
AT WEST COAST MEET
