So i changed my timimg belt about a month ago and had to bent valves. i replace the valves with new ones and the car ran sweet and quiet. Now a few days back i started the car to warm it up a bit before leaving to work and man there was this loud knocking i mean real loud i thought something was about to break! the knocking comes like from the engine right below piston 4 what could this shit be now ?? the knocking got louder and louder and eventually the car starts but dies after a few minutes .. im towing it to my friends house so we can take the bottom end off, so any ideas on what this could be ?
Here is the problem!
id bet crank shaft bearing had it happen to me tore it apart and the upper half of the bearing was gone and the crank itself was wearing into the rod.
If you can jack the front end up and take the head off rotate the crank till the pistons come up evenly and try to push them down by hand see if any of them move at all. if one does then there your problem.
