ok ive got my new radiator and ive got my haynes manual. i just need to put the thing in. anything unexpected i should look forward to while swapping them out?
radiator swap
i think they should swap right out. ive swap radiator before and only surprise ive gotten was the coolant leak etc. try not to spill soem on your paint. they leave a water mark that doesnt come out.
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Im lookin at title, thinkin you was gonna swap a oem rad to a diff style oem rad or something along those lines..Originally posted by GenDBlade View Posthaha. at this point the only thing im worried about with this car is running it until it can run no more. no more mods for me.
Your just swappin oem for oem.. Its str8 forward. Drain upper and lower hose, even the rad itself, the drain plug, which im sure you kno about already.
Question tho, can we oem 4th gen lude rad's. They r super thin compared to the cb's.
Mayb the top bolts won't line up, but the rad themselves, can we use it. I think it will give a cleaner look to the cb bay.
Thanks.
Also don't forget to bleed the system after you put fluid in.
