2 Blinks
    2 Blinks
    I keep getting two blinks from my tranny computer after my green S light starts blinking. Anyone got any ideas what that may mean
    Procrastination is a THIEF of time!!
    MY MRT
    http://www.cb7tuner.com/vbb/showthread.php?t=203992
    My First CB7
    http://www.cardomain.com/ride/705233/1990-honda-accord/
    u get those blinks when u jump the conector right??????
    if yes then here it is
    disconected lock up control selenoid valve B coupler
    short or open oi nlock up control selenoid valve b wire
    faulty lock up control selenoid valve b
    symtopms
    Lock up clutch does not engage
      yo dahub does your S light start blinking when u reach a certain MPH??
        Yeah it comes right on at around 3000. I changed both of the solenoids but its still doing it. Any help would be awesome, thanks for the help so far
        MY MRT
        My First CB7
          not RPM......... but MPH mine comes on when i hit like 50-55 not sure at what rpm tho and also does your car drive the same ??
            might be your transmission computer module (tcm) it self. open and check for burnt resistors. if you dont find any and you have access to another 90-93 accord that runs right try switching the TCM.
            92 DA9 // 93 D21 4x4 // 92 CB7
              maybe a new ecu as well, or does it not report trans codes?
                It runs the same and it starts blinking right around 40 - 50. i have two new computers im going to try later. hopefully that works
                MY MRT
                My First CB7
                  aiight cool let us knw cus i have the same problem and i just dont have the time to take the ecu/tcm outta my ex and put it back in so let us knw what happens cus i am having the same exact problem
                    ill do it tomorrow night and let you know.
                    MY MRT
                    My First CB7
                      Wasnt the cpu, i have to check Ohm voltage and maybe trace down a bad wire or go deeper into it
                      MY MRT
                      My First CB7
