i have a 91 accord ex with the alloys and for some reason i have to keep filling the two front tires with air. its not a problem with the tire itself (no holes, etc.), i already got it checked out. then about a month ago i took it to a mechanic and he said the tubing was loose and that he had tightened it. it was fine for two weeks but then the tires deflated again. i filled them up and a week later they were both down to 11 psi each. any ideas?
tires keep deflating
i heard sometimes the rubber thats inside the tire doesnt seal right for some reason...
11 psi is an air leak (no shit). when u took it in, did they put the tire under water?
another thing thats funnie..is that both front tires are doing it and not just one....are they the same kinda tire?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
best thing to do is remove the wheel, get some soap and water and mix the 2... then take a brush and apply the soap and water over the tire. if there is a leak somewhere; the soap will bubble up in the spot where there is a leak. be sure to cover the whole wheel and tire with the water and soap solution; including the valve stem.
