ok so i just swapped in the h22 with m2b4 and clutch masters stage 3 clutch and fidanza flywheel with new master/slave cylinders. The car was driving fine at first, but slowly it started getting difficult to put into gear, and it never wanted to shift into gear at high rpms. now the car will not go into any gear, when the car is on. when its off, everything goes in fine except reverse. i checked the fluid, its fine and we bled the system and still the same. any ideas before i take off this tranny?
