Sidemarker and rear window defroster switch/button dont work
    The other day i had noticed that my sidemarkers were not working (both left and right) and as well the rear window defroster button/switch did not work.
    I checked fuses to both all are good.
    Headlights(low/high) and bumper turn signals work.
    I disconnected the sidemarker and hooked the pigtails up to a battery.
    Now i only tried one could it be that the other may be out and this causing both sidemarkers to not work?
    Or could it be that there is a lose cable somewhere? If so where would i begin to check?
    The way my sidemarkers are connected
    > = wire tapped
    pigtales>some positive and negative wires>headlight turn signal wiring
    as for the rear window defroster i read all i need to do is get a new switch should i go ahead and do this?
