Engine is weird after tune up.
    Ok, i just did: EGR valve cleaning, fuel filter change and idle ajustment and spark plugs change.
    Before, after 5k rpm my f22 smoked blue, due to engine high miles so it burned oil. After i've done that little tune up, its now smoking bad BLACK pass 5k. And it smokes a lot! I know its due to a bad consumption of fuel, but why?
    Also, when i'm in gear (auto) rpm is at 900 rpm, when i switch to park, it jumps to 1,3k rpm and goes down slowly to 900 rpm. Before the rpm was at 650 in gear and when switching to park it just stayed at 650...
    What did i do wrong?
    Ok i dont have the idle problem anymore, i reajusted the idle folowing haynes manual and it worked. But i still have the bad fuel consumption problem, how do i ajust that?
