High beam problems
    High beam problems
    ok so, when i go to turn my high beams on, only my passanger side will work, and the high beam indicator in the car wont illuminate, so i tested to see if there was any power going to the plug and there isnt at all.... my regular lights work but not the high on the driverside... i dont really kno where to start, ive checked the fuses and they are fine.... any suggestions?
    Behind Every Successful Person...Lies a Pack Of Haters!
    Maybe the wires to the plug?
    Member's Ride Thread
    Originally posted by mercyboy
    I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
      keep testing those lines until you get power, follow the wires maybe theres short somewhere.
      AT WEST COAST MEET
      cb7rush: who has the tongs?
      JDMxDB8: i got a thong on...
      to get to see more of my cb click the link below.
      http://www.cb7tuner.com/vbb/showthread.php?t=130922
        thats what i thought to...so i traced them back about a foot or so and still no power.... i was thinking it was the lighting relay but i am still looking for the problem
          Check to see if a sidemarker or bumper turn signal also comes on. If yes most certainly a grounding issue.
          This sounds JUST like what happened when I took a bolt out of a plastic box under the hood. It was a ground box. On the pass. side under the hood, just under the part the hood "rests" on, about halfway up on the far far left side under the hood.
          It's a plastic little "box" with wires going into it. If there is no bolt put one in, if there is a bolt, remove, rub the connections with sand paper (to clean) put some dialectic grease on it, bolt back.
          If that doesn't solve the issue let us know...try other stuff.
          ____
