need oil pan what fits?
    im pretty sure i cracked my oil pan or my gasket is leaking or something
    im about to go out and jack it up to inspect
    my question is what oil pans will fit? what ones will be better than others?
    i really want an aluminum so it wont crack as easy just bend
    what motors oil pans fit on f22a4
    -Tyler
    i think you got that the other way around. steel pans will bend more than an aluminum one.
    but your choices for aluminum is h22a4, OBX or moroso
      thanks
      i must have got i backwards
      i want one that will bend easier rather than break
      can i just have my friend weld mine? very small leak
      -Tyler
        jb weld will work just fine if your wanting a quick, cheap fix. Just make sure you give it 24 hours to sit and cure. And be sure to clean off the area your puttin it on very well.
          f20b
          f22a
          f22b
          h22a
          h23a
          etc
          they're all the same, if you cracked yours, just get a regular F one, you're going to have to take it off anyways
          h22 will be 2" deeper, the reason why they take more that 4 qts
          Just do what PR CB7 said.
            thanks
            i figured out it was my oil pan gasket
            it sat so long ive replaced most of the rubber in the engine bay already
            -Tyler
              i didnt know the H22 was deeper than a F22
                me niether
                why would you want deeper?
                im ridin dumped i dont need any deeper of an oil pan lol may need a slimmer one
                -Tyler
                  You do not want to drive with a bent one anyways. It could block the pickup
