I've finally started my car after leaving it sit all winter so it wouldn't get any more rusty (thank you MN roads for all your salt). I used the time to get the 11" front rotors, MSD coil, intake manifold, injectors, etc. Now that I've got it all on though, I'm having a problem with the idle surging between about 1000-1500 RPMs and the CEL light comes on with code 14, Intake Air Control. I'm not sure if the idle problem is caused by the IACV or if they're two separate problems.
This has been somewhat of a PITA for me, I didn't realize that the JDM manifold would be harder to use than the USDM one. I have no FITV on the manifold or throttlebody, and the IACV is not plugged in because it has a 3 wire oval shaped plug, and the factory plug is 2 wire. Also, the stock IACV will not fit in place of the JDM one. So, would the fact the IACV isn't plugged in cause the car to have a pulsing idle? Or is there a vacuum leak separate from the IACV problem? I do know that I tried unplugging individual components like the cruise control or the rear motor mount or even the MAP sensor from the intake manifold and they didn't affect the idle at all. I also capped off their vacuum ports and that didn't help either. So I'd guess it's a vacuum leak somewhere, but I don't know how the IACV could affect it, like if it's unplugged maybe it'd act like a vacuum leak anyway? I also removed the EGR, but I don't think that'd cause a problem. Maybe I need to just start taking the manifold apart and putting RTV sealant on every surface where I have a gasket?
Anyway, does anyone know if there is any way to make the 3 wire IACV plug work with the 2 wire harness? Or should I just put a block off plate over the IACV? And do I need to be looking for an additional vacuum leak to fix the idle problem? Or is the IACV gonna be the source of the problem? Or the fact that I've removed the EGR?
