car choke or stall?
    car choke or stall?
    i have a 93 accord 5pseed. my problem is tht when i start the car it sometime choke sounds like it wants to starts but it keep on choking. it only happens in the summer. hope yall understand me
    sounds like the main relay to me. another possiblity is an ignitor problem.
    i would pull the main relay and re soldier it as shown in this DIY:
    http://www.cb7tuner.com/vbb/showthre...ght=main+relay
    later.
    Avoiding dirt at all costs
      ok. but one more thing before i check tht. i was wondering if it can b the fuel pump??? cause it only happens sometimes only. also can i just get tht little part tht i need to replace, from like autozone napa advance or the dealership?
        from what i've seen once a fuel pump stops working it's done because it's usually the brushes that wear out.
        the only way it would start and stopworking is if there was a wiring problem or another electrical problem (main relay).
        i think a new relay is $45 from honda. if you don't re-solder it. later.
          ok ill check on tht then
