First off hello everybody, this is my first official post of many. Quickey bio, I have a 92lx, of course its a damn Slushbox, basic mods AEM CAI (NO bypass!), Nakayama axel back, Jacobs ICE pak ignition, Jacobs 8.5mm wires, Optima Red Top, Mobil 1 synthetic, some ICE, Rota Gunmetal Subzeros 7.5" wraped with Kumho 711s 215/40/17 and thats about it, a few small cosmetic things no body kits or anything everything else is stock. Best time so far 16.8@82mph Rivercity Raceway San Antonio. I also post on texasracingscene.com, superhonda.com and not really anymore but, speedoptions.com
Ok again glad I finally found a site dedecated to just 4 gen accords, and i should be posting on here frequently. Here is my problem, I just got off work and so my car is ice cold, not litterally, so i jump in start it up everything seems perfectly ordinary. It idles like it usally does when very cold about 1.5K rpms and after about 30 seconds of warming up, it just turns off! Best way I can describe it is if you just plain ole grabed the key and litterally turned the key off. It didnt sputter, or gasp, didnt miss, just flat out OFF. At first i was thinging O shit Timing Belt!! Should i crank it or no? After deciding that it hopefully wasnt i cranked it again, and once again started right up as if nothing had happeded. (Shes a sly little girl I tell ya) idled for about 30 more seconds and then same exact thing!! Just flat out OFF. So I thought maybe one of the wires from my ignition has come loose may be the coil wire or something, poped the hood and looked throughly as much as possilble without tools and didnt see anything amiss. AGHhhh not good, once again jumped in Started right up perfectly normal and this time it didnt die after about 30 seconds, so I decided to tempt the fates and throw it d4 and take off hoping it wont die on the highway. No problems what so ever, and it hasnt done that since i last went to work a couple days ago?? Does anyone know what could be doing this? Distrubutor Crank position sensor? Not the fuel filter just changed that out shortly ago and i dont think its ignition related? Anybody please help, Thanks for your time.
Which is a good thing. Still so far so good on the dying problem. In my case cold cranking amps is not a problem at all Optima Red Top on my baby, i believe that its like 980 CCA, I mean the damn starter sounds like it getting too much power sometimes, i really noticed a differance when i bought it replacing my shitty WalMart Everstart POS battery! Sounded like a turbo up grade from NA not kidding it was kinda funney first time i cranked with the Red Top on the case. I was like O shit is the starter ok???
