Hey guys, yesterday I started noticing some power loss, excess noise (car sounds more like a Subaru than a Honda right now). I got home (was out of town for work) and it had gotten really bad. The lower the RPMs (below 2k) the louder it is, and the less power it has. Sometimes it clears up but it always shows back up when I let off the gas.
So far I've replaced the plug wires, plugs, fuel filter, and resoldered the main relay. I pulled the injectors out and found that the 'shroud' on one of the injectors (the end that injects into the cylinder) was cracked. Of course, I had to make it worse by dropping another one on the ground (fell out of my hand.. fml).
Fluids are fine, no exposed wires, ECU is good, PCV valve just replaced (though I am going to do that again). No vacuum leaks.
Ultimately, I'm thinking I got a tank of bad gas - or dirty gas. The fuel filter was releasing some dirty gas - next step is to pull the fuel pump and clean it out. Any other thoughts or ideas?
Any ideas?
Any ideas?
