the car is a 94 cd5 ex
the owner told me, since he bought it, its been doing the same problem
pulled the code and its a 9
cyp sensor,
steps i did :
removed the dis plug and check resistance on cyp, tdc, ckp sensor
cyp-.971oh
tcd-.950 oh
ckp-.960 oh
i look at the haynes manual and these readings are normal, either way i replace the DIS and nothing
the car had a chopped engine harness, and since the fans were'nt working i replaced the harness, got pretty much everything working, still code 9 car runs the same
i did a continuity test from the ecu plug to the engine harness plug
and im getting continuity on tdc, cyp ckp
checkd spark plug sequence, good, physical timing is also good
compression test read 180,170,168,170
here is were i got something different, i changed the ecu from a p0a to a pt6, the car still runs the same but no CEL codes
im kind of stuck right know, anyone ever had this problem?
cyp sensor,
steps i did :
cyp-.971oh
tcd-.950 oh
ckp-.960 oh
