Head gasket went
Had head checked out and resurfaced/ cleaned up
Did timing belt, water-pump, tensioner, head gasket, intake manifold gasket, distributor o ring,
Bleed coolant , Car idles at 2k then 500 then 2k then 500 etc..... If I put my finger over the fitv port inside the throttle body the car dies... I have no vacuum leaks or cels..
The mechanical timing is correct.... As far as the ignition timing though I marked the distributor and reinstalled in same position so it is probably pretty close... I need to get a light)
