want to get her to idle at 1000-1200rmp, need help
    im gona look in the haynes book also but just wanted to ask u all also
    i just fixed all problems with my car
    it was idlen at 2000rmp, now that ive got red of the slick in the throttle rotor it idles at 800-750 whci it should with all the things i have done to it and the 272 cam i have.
    question is...............i want to get the idle at 1000-1200rpm, can i tighten the throttle cable or something up to get it to stay or return back to 1000-1200rpm when not pressing the gas?
    thanks
    NEED RAP BEATS.....
    www.soundclick.com/akcidentaltrakz
    try this:
    right above the throttle body where the intake connects to (upper left hand corner when your facing it) there is a screw that you can turn to help adjust the idle...that should work
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
      tried that, all that did was increase or decrease the throttle response
      what if i move the adjustment bolt up or down (whatever direction) and lock the other screw and set it that way at the idle i want?
      thank that will work
      NEED RAP BEATS.....
        that does work..
        u have to tighten it so u remove the slack.. and once u do keep tightening it in the direction that removes slack so that it kinda pulls on the throttle a tad bit till u have ur idle were u want it..
        did this to my gfs 94 alty the other day.. fuckin altimas have two throttle lines.. bitches.. but its still a nice car regardless
        Praise The Lowered...
          sometimes the idle doesnt move when u use that screw.
          usually after i move that screw, i rev the engine and see where it settles...sometimes its soo bad that it wont move that the throttle body or something inside there is dirty....
          u can adjust ur throttle cable more but i warn u about the deflection that it should be within spec..if not it wont operate right.
          Retro!
          Hater
            thanks guys...
            i kno it cant be my throttle bodys dirty because i just put it on there. i reved the engine and everything then tried ajusting the screw....nuffin all it did was make the engine louder or quiter.
            i adjust the nuts on the cable. now it idles at 1500rpm
            im gona adjust it a few more times to get it at about 1000-1200rpm
            NEED RAP BEATS.....
