The dash board and tail is out. I checked the fuse and it was popped. I replaced it and watched it pop immediately after i tried to turn on the dash. Any ideas? It popped 3 brand new fuses immediately after i tried to turn it on.
Dash fuse 15a keeps popping.
Short to ground you have a power wire touching ground somewhere in the circuit check wiring at light sockets make sure the bare wire are not touching eachother
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
Originally posted by whitejdmcb7 View PostShort to ground you have a power wire touching ground somewhere in the circuit check wiring at light sockets make sure the bare wire are not touching eachother
U are rite my left parking light was touching each other causing my fuse to blow everytime I turn on my parking light,the power wire is ripp causing it to touch the ground. Thanks for the help gladly appreciated
