what is the shortes gear transmisson and a f serries and hserries can be missed matched right
same ?
I'm not sure what you're asking, because the words you typed didn't really make sense... so, I'll just answer what I THINK you're asking, and you can let me know if I'm on target.
The JDM H22A has the shortest gearing (M2B4 is the one you want) The transmissions on the H equipped cars will have shorter gearing than the ones on F equipped cars.
Yes, all FWD H and F transmissions will bolt to all FWD H and F blocks. The ATTS transmissions will not fit in the CB7, though.
he means gears in geneal.like take 5th gear out of the f22 tranny and swap it with the h22 5 th gear so its not all acceleration.and some top speed/gas mileage..and... i dont kno if u can swap them.sorry for the no help just wanted to clear the thread up so people understand..Originally posted by deevergote View PostI'm not sure what you're asking, because the words you typed didn't really make sense... so, I'll just answer what I THINK you're asking, and you can let me know if I'm on target.
I've wondered the same thing, actually.
Members Ride Thread: LX ~ EX ~ For Sale Thread
Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunder
If you want shorter gears, pick the one with shorter gears. You know which one that is, don't you? Or do you not know what cars those transmissions are from? (I'm assuming that this post means 92smokeaccord was seriously overestimating the amount of thought that was put into your initial question...)Originally posted by david17 View Postwhat trans would be better for all motor set up i have 2 options its a M2L5
or the M2S4 i want shorter gears wich one better
USDM F22A1 92-96 Prelude S COUPE:
Diff Type & Tranny Codes:
STD Only = M2L5
3.307 1
1.809 2
1.230 3
0.903 4
0.705 5
4.062 final
5th gear 195/60 R15
70mph = 2782 rpm
80mph = 3180 rpm
USDM H23A1 92-96 PRELUDE Si COUPE:
STD Only = M2S4
3.307 1
1.857 2
1.320 3
1.034 4
0.812 5
4.266 final
5th gear 195/60 R15
70mph = 3366 rpm
80mph = 3847 rpm
i dont no how to read this to see what one has shorter gears i can get ether one of these i want the one with shorter gears. i have a h22a4 with the type s set up 91 4 door lx
Well, going by what I said above... you don't even need to read the numbers. The transmission that came on the H-equipped car has shorter gears. Basically, the higher the number, the shorter the gear.
The M2B4 would be a better choice than either of those. The H23's transmission has longer gearing than the H22's.
