I've trying to remove my erg valve on a 92 LX and I can't seem to get my socket wrench to fit without taking the whole mani off... anyone done this without taking the mani off?
EGR valve Removal problem.
yeah, i just used a long extension, and a small/short socket.. came right off.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
I had similar problems, this is what I did:
1. Try a wrench, it worked better.
2. Take off the black cap thingy on top off, that might give you a little more room.
3. Use a short socket.
4. Put the socket on first, then slip the extension on. It won't go all the way, but if you can get it in far enough, it'll turn.
Hope that helps, good luck!
Btw, are you using a block-off plate? If so, where'd you get it from, I need one.-Jay
Replece no. clean yes.. as well as your egr ports. the egr valve reserculates exahust gasses back into the manifold so they can be burn once again. less smog that way. I think.Originally posted by spdACCORDinglywhat is an EGR valve? what does it do? and at 105000 miles should i change mine?
