Is there a DIY on it? I cant find one.. Need a little help haha I got the valve cover off and now im just wondering what do I do next? Is it even possible to take the head off while the motor is still in the car? My Haynes manual says to do it while its out.
Head Removal
Set your engine at tdc then you have to mark your timing. As in your crank pulley, water pump etc. Loosen the tension on the timing belt and that should let the cam gear(s) loose. Remove the cam caps as specified in the Haynes manual. Remove cam and you should be able to see the head bolts. Remove the head bolts as specified in the haynes manual and VUA LA.
I did skip a few steps but that was just drain coolant
Also you must remove the tension from the driver side motor mount by jacking up the engine a bit and remove that mount to get to the timing belt with out removing your engine.
Sorry if I am unclear.
Rip It Up
Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
i vouch for my Brothas
Yeah Woops forgot to mention this as wellOriginally posted by wed3k View Postare you trying to change the timing belt or leave it? that determines the next few steps.
Rip It Up
I dont know how old the belt is. So yea I guess I should change out the timing belt but knowing me I might procrastinate and just want the damn thing running and use the old belt.Originally posted by wed3k View Postbegin by unbolting the exhaust manifold, intake manifold and distributor. remove the radiator hoses and the one heater hose.
Ok. I got that. Thanks. Anything else? I heard theres special studs that I have to replace after I remove the head... What are they talking about?Originally posted by Extacee View PostSet your engine at tdc then you have to mark your timing. As in your crank pulley, water pump etc. Loosen the tension on the timing belt and that should let the cam gear(s) loose. Remove the cam caps as specified in the Haynes manual. Remove cam and you should be able to see the head bolts. Remove the head bolts as specified in the haynes manual and VUA LA.
Burnt valve. Runs on 3 cylinders till compression builds up enough to force the valve to work.Originally posted by UNeeKToNy View Postwhat's the reason why you want to take the head off for? hell i just got done rebuilding my entire valve train for my white cb7.-Will
drain rad, remove radiator hoses. unbolt valve cover, ps pump, alt, unbolt bracket from im mani to block. my not be the best way but unbolt cam gear, pull timing belt off, bolt cam gear on how it came off. unbolt downpipe and headers. take 8 head studs out. pull head off.
not too hard just takes awhile doing it the first time. i took to midas to have them time it, i was only 1 or 2 degrees off which is within oem specs
They are called head studsOriginally posted by Bullhorn7 View PostOk. I got that. Thanks. Anything else? I heard theres special studs that I have to replace after I remove the head... What are they talking about?
Rip It Up
