Ignition Replacement help
    Aight peeps sorry for makin a 3rd thread but now i know what iam doin finally REPLACING IT!..... I bought a ignition with a key for 50$ so now I need to put that shit in.. So can anybody please post any problems I might run into....
    My car isnt in front of my house its a couple ,miles away so what tools will I need ya think? I know i got to take the sterring wheel off so what problems am I going to run into??? I printed the manuel up for rthe steerring wheel and the ignition replacement so I can know where everything is at... Thanks in advance..
    I think you need to drill out the old bolts that hold in the cylinder. They have heads that snap off when you install them (so yes you'll need new bolts; dealer parts).
    This is what I remember from the manual so I may be mistaken.
      u need mmmm the very very very small screw drivers. the 6 spoke star screwdriver i think. there is a bolt that is very small. other than that only screw drivers flat and start ones.
        Noooo, you don't have to remove the wheel, you'll have plenty of room with it on. Also, you don't drill out the old break-away bolts, unless you just feel like doing it the hard way. Just use a small chisel and a hammer to turn the bolts, you should only have to tap them once or twice and then you'll be able to unscrew them the rest of the way out by hand.
        00 Jeep Grand Cherokee 4.7 V8 4X4
        92 Honda Accord LX
        95 Honda Civic CX
          I only remember what I've seen in the service man Never said it was the best way to do it
            thanks all will be doin this tommarrow... will post update..
              wowo I just w as just about to go out and i lost the manuel paper i printed out off of www.honda.co.uk somebody likned me to it in one of these posts but now i cant seem to find the removal instruction.... FUCK can somebody relink me, when I go to that site and click on ignition switch it comes up diffrent shit..
                Well I tried to get of fmy ignition and didnt get it.. I couldnt get those ribbits off????
                So I assume I need a drill like the manuel says... But it doesnt seem like I can get a good angel but can I jsut drill that shit out????
                And another question is after I drill those ribbits out.. What do I put in to subsitute those ribbots probably some kind of large screw? Does anybody know the size???
                  Trust me dude, you don't need a drill. There was an ignition switch recall and I've done hundreds and hundreds of these damn things. Like I said, a hammer and a small chisel. As far as the bolts, you gotta go to the dealer for them.
                  92 Honda Accord LX
                  95 Honda Civic CX
                    Do u put the chissle between the bolt an dclamp? or in between the clamp and the bottom clamp where the screw goes through ..iama try it tommarroow thanks for your help.
                      hey Mrhonda or does anyone know what size screw and bolt or nut I need to replace those rivots with??? I called the honda dealer and they are acting lke they are retarded...
                        Well I guess the New Solution is DRILLING THE OLD IGNITION OUT.. A lock smith came and drilled that shit out didnt take nothing off he just drilled the fuck out the old ignition and it fell out. Problem solved
